  • Welcome to the Installation Support Thread!
This dedicated channel is designed to provide assistance and guidance to users who encounter any issues or have questions while installing DUDUAUTO devices. Our knowledgeable community members and expert technicians @dudu-lai are here to help you navigate the installation process smoothly.
🌟 What You Can Expect:
  • Step-by-step installation guidance for various DUDUAUTO products
  • Troubleshooting tips and solutions for common installation challenges
  • Advice on best practices for a seamless installation experience
  • Answers to your specific installation-related questions
🚗 Whether you're a seasoned car enthusiast or new to the world of automotive upgrades, this thread is your go-to resource for all things related to DUDUAUTO device installation. From wiring concerns to software setup, we've got you covered!
💡 To get the most effective assistance, please provide the following information when posting your question:
- The specific DUDUAUTO product you're installing
- Your vehicle's make, model, and year、Car Center Control Pictures
- The current CAN bus model and version in use
**- A clear description of the issue you're facing
  • Any relevant photos or screenshots that may help illustrate the problem**
🤝 Remember, our community thrives on mutual respect and collaboration. Be kind, patient, and supportive towards one another. Together, we can ensure that every DUDUAUTO user enjoys a seamless installation experience and unlocks the full potential of their device.
Let's get started on your DUDUAUTO installation journey! 🚀
24 days later
Hi i have a dudu7 8-128 screen in a 2014 kia soul with a simple canbus. The screen will not recognize any usb or dvr. I have tried so many options to get it to work. Can someone please help?.
    Denny7 I have tried to help you on Telegram. I think the best solution is to contact your seller.
    Ok thanks the block me for some reason. I connected the seller he keeps telling me to try everything you did and send videos. But no luck. Just keep saying he is taking to engineer.
    5 days later
    Where can I send error log files? Is there an email for the entire programming team?
      PolJet Please do not double post. Ask your question and wait for an answer. This is a forum not a chat. You can make a new thread where you can upload the error files and the team will check it.
      12 days later
      6 days later
      2 months later
      Здравствуйте будет ли поддержка климат в Нав баре geely coolray и будет ли работать штатная атмосферная подсветка
        Viktorius I have same problem with ac controller
        2 months later
        I have a 2018 silverado 1500, with a dudu7 10.3" display, 12x256G and I have a cable with purple and gray wires between maile and female connectors, with a single purple wire with a 2 pin plug on it. It appears to be for the steering wheel controls, but on my 18 silverado, the connectors do not seem to mate up with the ones on my truck. Is this the correct harness for steering wheel controls on my silverado?
        22 days later
        I figured out how to fix it.
        That harness does not work for steering controls on a 2018 silverado.
        Should be a tee harness that plugs in under steering wheel to the clock spring. I could not get such a harness thru Dudu so here was my fix.
        Remove clockspring connector under steering wheel. 2nd wire position is green/black data wire. Peel back some of harness material and tap into that green/black wire with a second wire. Run it up to radio. Connect it to a purple wire labeled KEY. (There are 2 others labeled KEY1 and KEY2 don't use them) The steering wheel controls worked immediately with no other messing around.
