dudu-lai Here are detailed instructions for use https://wiki.dudu-auto.com/en/%E5%A4%96%E8%AE%BE%E9%93%BE%E6%8E%A5/%E8%93%9D%E7%89%99%E6%96%B9%E6%8E%A7
ivanharti I have the same problem I can't pair the Dodu steering well controller with the head unit. The Dudu7 does not find nothing. The steering wheel controller is always on ? How do put it on?
MihaiFlorin ivanharti @Kendricktb75 first you have to install a new battery. It doesn't come with a battery out of the box.
psihog For future reference. I used CR2032 battery. battery slot slides out from the top. Hold middle button to pair. LED between blue and red buttons will blink.
Neckbone Will any Bluetooth steering wheel controller work? It will take a month or more to get Mekede official one.
DUDU-Meng Neckbone This is the only steering wheel controller available for the docking system. We are not sure if other steering wheel controllers will work.
Neckbone DUDU-Meng I did get a cheap one off Amazon that actually works pretty good. I already have steering wheel controls but when I’m in the back adjusting stuff on amps and dsp it’s nice to have one to carry around
robdx2 I have one of these, my DUDU unit has not arrived yet though tried to test it with my current TS18 (eonon) unit but would not find it. Hopefully DUDU unit will clear UK customs soon
Johnno152 For anyone that has the steering wheel controller, I’d like to flat mount this on my dashboard or similar instead of the steering wheel. Does it pop out of the wheel band at all or is it fixed in place?
Gwinambele you have to mount it with that band. i have put it on my handbrake. it has round back so you cant mount it on flat surface. too bad. also too bad that color dots are not backlit :/
brokenman90 My Aliexpress sourced Bluetooth multimedia remote button wont work either. It works fine on my Android phone, just pair it and away it goes. I dont really understand why we cant do the same thing on the Dudu. But Dudu only allows pairing of smartphones. No other types of devices can be added.
taptap I also cannot pair the dudu Bluetooth SWC, inserted a new battery, but no LED lights up on the controller when holding the middle button / any buttons.
DUDU-Meng taptap The button will not light up when pressed normally. The indicator light will flash briefly when you insert the battery.
taptap When I insert the battery ( with the negative side pointing up, same as in the picture in this thread ) , no light flashes
DUDU-Meng taptap The batteries might be dead, or the remote could be broken—I'm not sure. You should check it yourself. Under normal circumstances, when you insert new batteries, the indicator light should flash once for about one second.
