  • v3.5 beta 241118: Radar screen activated erratically
dudu-lai ,
I tested it on my desk, as you can see in the video, the Canbus message "2E 25 02 02 00 D6" enabled the distance sensors and "2E 25 02 00 00 D8" disabled the distance sensors. If you have any questions, I can simulate Canbus messages on my device and help.
log-2024-12-17-0.zip
1kB
I have upload a Canbuslog.txt
@Bettman66 @surfer63 Problem solved, need to upgrade canbus, please contact LSDUDUlai via telegram and I will send you the upgrade software.
18 days later
I have had this radar problem and got the updated canbus firmware, put it in the "local" directory, and successfully flashed the Canbus with the new firmware, and then reset the system as requested. It has totally fixed the radar problem, but unfortunately for me, after flashing I have no SOUND out of anything. Radio, has no sound, no sound through carplay, nothing.
Does anybody have any suggestions on how to fix this. I have tried looking through the sound setting on setup but nothing seems to work. System 241222. Cant seem to imbed the screenshot into this but the Canbus is now 'RZC (Raise)-Volkswagen-Yeti(2031667) -VW-RZ-08-0038 212.03-HSE"
Help appreciated
    johnyfalco didn't have this - but try to unmute. What volume is showing when you raise it?
    Update. I fixed the above, no sound problem by disconnecting the negative battery terminal for ten minutes, then reconnecting, and now I have the sound back.
      johnyfalco
      Thank you for reporting. This is/was a known 'bug" on the older FYTs. I had it myself on the PX5 and the sc9853i when doing a canbus upgrade.
      Really unplugging power, or shortly removing the main fuse would fix it. So obviously the unit should be completely without power. That suggests that if you simply wait approximately 3 days, when it completely shuts down and draws no power anymore, could solve it as well. But that is a guess.
      So still an issue?
