• Bug FeedbackError handled
  • App store Some apps are blocked by Google Play Protect and cannot be installed.
Hello
Two app below
Files
Multimedia
    gils You must disable play protect in the settings of your Google Account and everything will be smooth
      MihaiFlorin this should be fixed somehow though. Disabling Google Play Protect isn't safe thing.
      The problem is here that it isn't on the top.
      This currently only disables Google's protection
      @DUDU-HUANG giving a workaround doesn't mean the error is handled lol
      Google protect prevents malicious apps being installed, whilst DUDUOS apps aren’t malicious, there are others out there, that protection will be removed ultimately making DUDUOS devices less safer.
      Ideally the AppStore installation prompt should be pushed back a layer below the google protect prompt, this would then allow the user to decide to allow the app installation without disabling google protect completley.
      Some apps that are not published on the Play Store will receive false positives, and you need to manually allow installation or disable protection.
        YAOXILONG yes, I think that’s the issue here, the manually allow is hidden by the DUDUOS installation prompt, so you cannot manually allow.
        If you close the DUDOS installation prompt, this allows you to select manually allow, however you then need to click on the DUDUOS install again and then soon as you do , you get the same google protect prompt as if it’s forgotten the file previously selected to install, your stuck in a loop unless you fully disable.
        I haven’t tried this on test15
        10 months later
        i am dudu 7 latest 3.5 release and i cant get over this block, despite allowing the app to be install the block comes back. how do i fully disable. can you share guidance, i was blocked from installing dudu tpms app. it was flagged by the protect prompt. thanks
        3 months later
        Hi, I have same problem, cannot install osd themes. I'm on 3.6.0.
        A way to bypass is to open google play, click account icon -> play protect icon-> gear settings icon and pause or disable playprotect
        This is with all android devices. Disabling google play protect is standard/normal. And if you are side loading you have to enable instal from unknown sources as well in the android settings. It is the same with my nvidia shield tvs and firesticks. Any android based os. If you dont do these steps you will not be able to install and if you do install google will disable the app eventually on your system and you will have to re enable or delete and then reinstall the app.
