surfer63 JhonnyD Is realzoulou stopping with DAB-Z? I haven't seen anything about that although I must say that I do not follow his XDA thread very intensely lately. But searching now, I can't find it either.
JhonnyD surfer63 https://xdaforums.com/t/dab-z-v2-x-usb-dab-dab-app-official-support-thread.4572071/page-26#post-89713534
surfer63 JhonnyD Only one line in the middle of a message? I did miss that one. He should be more informative. Anyway, I have used DAB-Z for about 4 years with great pleasure.
JhonnyD In my case it was blitzer.de. But i found the correct settings. And it just was on DUDU6. On DUDU7 it was ok. But atm i swapped to DABDream and will stay there.
Bettman66 surfer63 I have also been using DABDream since Dudu7 because I have less interference on my home route. That must have something to do with the audio buffer.
HondaCivicDriver surfer63 @JhonnyD I also wanted to replace DAB-Z by DAB Dream but what hindered me was that DAB Dream could never find my USB-dongle DAB+ antenna. Nothing. Strangely DAB-Z never had any problems, so I don't think my hardware is compromised.
PatrykWaw frorei what dab+ adapter you have? I have already seen usb adapters that are not recognized by android
frorei PatrykWaw https://www.aliexpress.com/item/1005007037902190.html?spm=a2g0o.order_list.order_list_main.119.21ef18027dVqRV
PatrykWaw JhonnyD OMRI is in a early alpha stage, and it is known that many things do not work. This is not a good version for comparing whether a particular adapter works or not.
HondaCivicDriver JhonnyD Sorry for quoting my earlier post but do you have any hints? "I also wanted to replace DAB-Z by DAB Dream but what hindered me was that DAB Dream could never find my USB-dongle DAB+ antenna. Nothing. Strangely DAB-Z never had any problems, so I don't think my hardware is compromised."
frorei gismo yes might be. The "only" ref I got is that the light on the antenna-part is blue - so some power is in that unit. BUT if the USB-part actually works - might have to buy a "REF" unit og higher quality..
oxy93n Today i installed an Erisin Twin Tuner USB DAB+ https://erisin.de/products/es394-erisin-dab-empf%C3%A4nger-mit-dual-scheibenantenne-tuner-3m-mcx-empf%C3%A4nger-verst%C3%A4rker-f%C3%BCr-android-autoradios-usb-port-anschluss tested it with 3 Apps DABz starts and when i hit search it closes with "dab usb device hardware error" DABDream starts the search but still stay at 0% after 10 minutes. DAB+ APP Starts and ends with an error to when it try to search. Any Help what i can do now would be nice
gismo oxy93n confirm that the device has a chip set that is supported by the apps you use. I doubt it...
