Hi everyone. I have DUDU7 head unit. I don't know what I did wrong, but the Touch screen sound stopped working.
But I have this feature enabled. Maybe there is some other feature that affects it. Any advice?
2 settings that I can think of - you have gestures enabled and gesture finger configuration mapped properly to your desired output?
picasso1850 I don't use gesture function.
When I bought head unit a few days ago, the "touch screen sound" feature was OK. When I touched the screen, a "beep" sound followed. I noticed today that it doesn't work anymore.
Robin Oh im sorry, thought you were talking about volume control. Not sure about that touch beep setting.
Robin Check this setting.
MihaiFlorin I've tried turning it off, and on. No change.
Robin maybe a reset to factory settings will help? I really don't know...
Robin Reboot the HU once you turn the setting on. I don't know specifically but it seems sometimes a configuration change require a reboot...or maybe thats just me thinking so.....
MihaiFlorin How do I make factory reset?
Robin In the android settings/system/reset options (pasword - 3368)/erase all data (factory reset). Just let me know if it solved your problem. I am curious too.
MihaiFlorin Unfortunately, factory reset didn't help me
Robin Than I really don't know how to help you. The other sounds go through the speakers? Like music and so on?
MihaiFlorin Music is ok. But today I discovered that when someone calls me, there is no ringtone from the speakers.
Have you checked the sound mix settings?
I've made a little progress. When I have the speakers connected via the internal amplifier, everything is ok. Beep soud and ringtone is ok. When I connect external amplifier via RCA output, The problem occurs. No ringtones, no beep sound.
Today I tried to connect my amp with DUDU7 via fiber optics. Ringtone and touch screen beep sound is ok.
This means that this error only affects the rca output.
