Ok thx! I solved it through the mic supply voltage change but good to know for others. Will also look at config.txt and how to flash changes at some point - is guidance available? Haven't seen it being covered in the wiki.
Edit: Have looked at the image and seen config.txt as well as lsec6318update so assume it's like in the "old" days - just these two files on a USB stick will flash a modified config.txt. So the question is now limited to the correct name of the setting. Is it still persist.audio.mic.senstivity and is it otiginally set to 1? My config.txt is pretty empty, just contains
#test
#persist.dudu.oem.logo=true
