caolz
Good morning,
I use the 2008 model because on the 308 model the buttons do not work as they should.
Anyway, I also did the test with almost all the models and Peugeot 308, 2008, 5008.... all, and the same thing happens when the engine turns off it stops showing the animation.
I know 100% that it is not a configuration or CAN box problem, with the mekede OS this worked correctly.
And the animation of the turn signals was also shown in mekede OS, which in fact, even if I activate the turn signal option in DUDU, they don't work either, but for me it is important to know the status of the doors, especially if a child leaves the door open, etc.
If I activate the option to print the can bus on the screen, I can see how the opening and closing messages continue to be received through the can bus, but I do not know the reason why the status of the doors is no longer shown.
My only conclusion is a bug in the OS, as I mentioned, the rest of the controls that work through the bus, such as the controls or climate controls, still work and are shown on the screen, but the animation of the doors is no longer shown.
Thank you all for responding to me, I hope you can finally help me and resolve this bug.
If you need any additional information or test that you want me to perform, I am at your disposal.
And thanks to the DUDU team for your work.
