  • Peugeot 308 T9 2016 canbus
Hi all.
Purchased myself a dudu 7 so installed the dudu6 into a 308 T9. Overall everything is working the only major issue is that the car doesn't have physical climate controls. These are controlled by the factory screen. The only way to get this back is to go into the car settings then AC.
I want it so I can access with just one press of a app. But currently have to work through menus.
Tried to set the canbus to multiple on both raise and hiworld to see if it would work with the built in dudu app but no dice.
Tried to even set a short cut to the car settings and then tried to find the app but no luck.
Any ideas?
    Kann man das nicht mut der unteren Leiste steuern?
      JhonnyD Unfortunately, AC control from NavBar for Citroen/Peugeot cars does not work
      Jon199102 There is one option to control the AC with one button. A little complicated , but it works. Install from DUDU AppStore "Touch Assistant" and it will show you a floating icon with a "snowflake" symbol
        Jon199102
        I have the same car as you, and I wanted to ask you if the screen shows the animation of the doors when opening or closing with the engine running but if I turn off the engine it no longer shows the animation, does this happen to you too? Thanks, regards
        PatrykWaw hi. I can't see a option on the store. Any ideas why I can't? Shows all the systems apps and others
          Jon199102 1.Need to provide your car model information
          2.Provide your CANBUS protocols
          3.If it is convenient, you can shoot a video for us to see.
