• Update Bulletin
  • DUDUOS_DUDU7_Global_241008 Update!
mo_danish It depends on the car model and the canbus decoder. To have those you must have a canbus box, sorry. Otherwise you are stuck with the stock FYT vehicle details. What type of car do you have? Brand/model/year?
    mo_danish -> This is the "Attitude indicator"
    Funny typo 😃 It is the "Altitude indicator".
    But indeed: the menu option vehicule leveling is better although it does not entirely describe it correctly either.
    The pitch and roll are the correct terms to describe the movements/positions.
    YAOXILONG 13. Оптимизированный диапазон эквалайзера LPF и HPF
    В новом обновлении этих настроек недостаточно для построения качественного звука в автомобиле! Можно ли исправить диапазон HPF до 10Кгц, как на картинке. Иначе пользоваться встроенным dsp нет никакого смысла.
    Iv tried ota update but it's saying i have latest update, i downloaded this manually and tried to do offline update but it's saying my version is already newer? I have dudu 7 13" 12/512
    JhonnyD
    im missing it too
    i also wonder why this shortcut leads to different setting than system settings>sound.
    half of the text in that EQ are chineese. Or was since its missing now.
    One suggestion:
    Can it be possible to add USA or North America to the region?
    Thanks
      moreyruiz
      This region is not for phone/SIM or wifi. It is for the download servers. Users from Russia did not have access to the Chinese servers. So dudu added a few extra servers to cover the entire world.
      You can simply download from the European server.
        surfer63
        Do it doesn't matter what server I have? I'm from Poland and I have Russian server in unit info.
          A thing that I noticed is the AC temperature.
          I selected the Fahrenheit (F) but the System continues displaying Celsius (C) after the number.
          The numbers by itself matched the Fahrenheit temperature set on my AC, it just the letter. Istead of display the F it display a C.
          When I go back to the radio settings to verify what I previously selected (F), it is reverted to (C).
          Ej.
          If my AC is set to 65 degrees Fahrenheit, intead of display 65F the headunit display 65C
          Thanks
          Gwinambele
          It should not be a difference which server you chose. Theoretically the server closest to your location should be the fastest for you.
          5 days later
          JhonnyD I also am missing this and I used it regularly to adjust subwoofer volume level. Please bring this back!!
          mo_danish hey mo, er du dansk? 🇩🇰 Hvilken enhed har du? Har du nogle offentlige post på feks Instagram med billeder mm? Mvh PEM
          Rød grød med fløde
          4 days later
          YAOXILONG I cant download toppal also i have the latest firmware 241008 on my dudu7. When clicking on toppal update via the OTA update nothing happens. Any solution thank you
            10 days later
            YAOXILONG
            Hi,
            Can't seem to get download to work keeps saying "Update verification has failed! Version may be too old or the file has been modified. Please retry download and try again." I did remove the "updatecfg.txt" as to not lose my data and rezip'd the file back up and tried the download. May that be what is causing the issue. I'm on version: V240927. I wanted to update because of issues I'm having with PIP not opening up and thought this update would fix the problem.
            Thank you in advance for any advice you can give.
              Neoj5680
              Keep the files as unpacked in the USB(only the files, not the folder) and don't go to OTA menu to update. It will automatically detect the upgrade files.
