  • Dual lens rear camera.
I just installed DUDUAUTO 12G+512G DUDU7 A7870 11inch in my Fiat Ducato camper.
The camper has an ahd dual lens rear camera (brand "esx"). I can get one of the lenses to display as backup camera. The other lens is more like a rear view mirror. How would i be able to get that lens to display on the screen (while driving). My Eonon unit allow this (with the f-cam app) as this recognised the second lens as front camera.
The camera has two video outs. I have the backup camera connected to the rear view connection and the rear view mirror view connected to the cbvs in. But i have no clue how to bring up the image.
Anyone has any tips to get this working?
    Afterforever666
    I suggest to use a camera input siplter in the link bellow.
    Just found this amazing item on AliExpress. Check it out! C$16.40 | 1PC Car Video Switching AV Cable Two In And One Out Reversing Image Driving Recorder Video CVBS Analog Signal
    https://a.aliexpress.com/_oorb3O9
      ahmedjassm thanks for that tip. How does this work then: there is an acc and gnd connection which i assume is for the power supply. How would it know when to switch between the two lenses? What will trigger the switch? The image on screen is now from the lens i connect to the reverse camera input on the radio, but how do i make it display the other image (without being in reverse?)
      Maybe the simpler question to ask is : imagine i have front camera (any brand) how would i display the image of that on the screen while driving?
        ahmedjassm that should work. I ordered the cable. Not sure yet however through which app on the duduauto radio i will be able to show the camera feed while driving.
        Afterforever666 если вы подключили вторую камеру к входу (aux cvbs in), то для показа изображения с этого входа нужно запустить приложение AUX.
        I have problem with the rear reverse cam.when I on Google map..I switch to reverse gear..it's a blank screen. When I on other apps (example music player), there is no problem. What is the possible cause?
            @Afterforever666 , would you be able to share a pic of your setup?
            I am really curious what the 11 inch model will look like in a fiat ducato camper.
            Mine is on it's way and it's exactly the same unit :-)
              Problem solve after latest update
              superdaan500
              @Afterforever666
              Great! My father's Ford Transit Nugget Plus will also be having an 11inch Dudu7 anytime soon.
              I'm much looking forward to it. I also started asking some RV related requests here, e.g. the car model type in the 360 views or in the parking radars or so since RVs are at the moment totally not accounted for.
              I am not sure whether dazzling light or glare is an issue for you but it was on our older unit with an obsolete IPS screen. We just bought it 1 year ago but from Navirider "brand" on AliExpress but it was total rubbish since you couldn't see anything on the screen. Do you consider a shade to avoid reflections in summer? Looks like you're from England or the Netherlands, aren't you. ;-)
              And does yours work so far?
              23 days later
              @Afterforever666 thank you. Which camera's did you use for the 360?
              I don't seem to get a connection with the one I installed. The ones from Dudu (307?) do work. Did you use the mirror camera's perhaps on the side of the camper? Can you make a picture perhaps of the side camera's ? thank you so much
