  • How to safely remove/eject a USB-stick
I asked the same thing on Telegram in the DuDu7 channel, but the amount of messages is so high and going so fast, it got "snowed under".
How do I safely remove/eject a USB-stick.
I can't find that option in DuDu7.
It was always available on every FYT unit so far and also on the Mekede 7.
a month later
its always safest to pull out 😉
Still the question remains. If you simply pull out the USB-stick, the "dirty bit" is always set due to the fact it was removed incorrectly.
The previous FYT Settings app had the option under Storage, to remove a USB mass storage device safely.
That is currently missing.
It is one of the big errors that cause faulty flashes of firmware. In 95% of the cases where you see a wrong flash in the forum or the Telegram channels, it is because the usb stick has some corruptions.
