_~~[Feature request]
Currently I only use the DuDu launcher on my Mekede unit. Switching to DuDuOS in a few days.
The music widget does not have "marquee" text (horizontally scrolling text). It is fixed and longer titles or artist names/combinations are not automatically scrolled, but stay fixed and are therefore incomplete. The text fields are not long enough and should therefore scroll horizontally.
It is an extremely simple font setting either in the code or in the layout xml.
In kotlin that would be "android:ellipsize" and "android:marqueeRepeatLimit" in the xml.
(But I assume the developers know perfectly well ; ) )
I currently do not know if this is only the DUDU Launcher, or also the launcher in DuDuOS and DUDU6/DUDU7.
(I assume DUDU6 and DUDUOS are actually the same apart from the underlying hardware)
Thanks~~_
That was Yesterday. Today, after I had to reset my unit via the reset hole, it did work. Maybe some things got screwed up just before the "total block of the system", or I simply was wrong (has happened before 😉 )
