Chrisjohn Chrisjohn Although when I use the usb- c output I have no control over the volume as expected.
Mikescotland Chrisjohn possibly this model does standard android usb audio over usb-A (like any android host device from android built in mixer and bit perfect usb audio over usbc) Can't confirm as have Dudu7.
Mitz When I was playing from USB-C, volume controls on the handwheel did not work. I had to use my DSP controller. Never tried with USB-A. I would like to know what's the best way to connect from DUDU7 to my DSP ? I mean Which out ?
Tomaso Mitz Na ten moment dźwięk z USB do DAC to najlepsza opcja pod względem jakości dźwięku, jedyny minus to zewnętrzny kontroler głośności z DSP
Mitz Tomaso True. My DSP has OTG input (USB3.0 A). My question is which USB do I choose from DUDU7, will that be USB-A 3.0 or the USB-C from the back of head unit ? That gets into my DSP Otg input. Which has better output?
rille It doesn't matter which USB you use. Why should it make a difference? USB 2.0 is sufficient for stereo audio even in high bit rates.
