acvdmolen if its important to you consider using professional measurements device with a pressure calibration. When you use android HU even the location of the antenna is important. Are you using an antenna from the DUDU kit or some other? Cheap antennas, as well as factory car antennas are often produced only for one frequency, for example, only GPS. And there are several navigation systems available in Europe: GPS, GLONASS, Galileo, Beidou
