chicken Hi need help to disable the AC pop up when press heated seat button. It doesn't pop up when adjusting fan speed or temperature or anything else. ONLY WHEN HEATED SEAT BUTTON PRESSED. Checked settings all set to not pop up. Help appreciated. car: Golf Mk7
DUDU-Meng chicken When asking questions, please provide a screenshot of your current system information. Also, clearly state whether this issue occurred immediately after installation or appeared after upgrading from one version to another. Thank you. https://forum.dudu-auto.com/d/1674-important-notice-feedback-on-bugs-must-be-prepared-system-information
chicken DUDU-Meng Hi, thanks for reply. Here is more information including the 'automatic pop up' settings. There is NO setting for the heated seats on the list to either enable or disable.
DUDU-Meng chicken Please install this APK file for testing. Let me know the results. Thank you. https://drive.google.com/open?id=1fnFR1fPhmNG4IuySWTpTP8TelHSUrty4&usp=drive_fs
chicken DUDU-Meng Actually, now there is a double volume slider since applying this fix ? (see pictures) How do I revert back to the single volume as before. Dont like it really lol.
DUDU-Meng chicken Another volume slider is used to adjust navigation volume. It is currently in the testing phase.
chicken DUDU-Meng Hi I understand. When you gave me the fix for the AC pop up, it also has triggered this double volume slider appearing on my unit. I dont want it - is there any way to revert back? Thanks
DUDU-Meng chicken The new version defaults to two sliders. Future versions will include a toggle switch to switch to a single slider.
