pkrystek I downloaded it and installed from Google Play, but it doesnt search the music from USB Is it sth to enable?
DUDU-Meng pkrystek No action required—I've tested this Fiio Music and it can directly read music files from internal storage and USB drives.
pkrystek DUDU-Meng Did you install it from Google Play? I tried to search for music, checked USB, and it showed me 0 files found. Native music player is finding with no problem
DUDU-Meng pkrystek Yes, it works perfectly. If you're having trouble finding music files, I'm not sure what the reason is either.
surfer63 pkrystek Did you already try one of the other USB connections? They sometimes behave differently. I has been mentioned before.
DUDU-Meng admaximum For versions compatible with Fiio Music, you can install and test them. https://drive.google.com/open?id=12_v77JTTJcPjIyDkJi6CJMdyF-FWTay9&usp=drive_fs
Trouble DUDU-Meng Hello. Please add a default music player. This is an app used by many users. I've requested this several times, but it hasn't been added. Thank you. 'KMPlayer – 비디오 & 음악 플레이어'에 대해 알아보세요 - https://play.google.com/store/apps/details?id=com.kmplayer
Trouble DUDU-Meng Yes, it's not difficult to use. It's an app used by many users, and its developer is actively updating it. Please help. Thank you.
Nechigawara Nechigawara I saw @DUDU-Meng post the screen of Fiio Music and saw most right PIP with the background so I ask him if Fiio Music come with it's own PIP or not. I didn't talk to you. EDIT:: Now I know it's DUDU loading app in a PIP.
DUDU-Meng Trouble admaximum Fiio Music+KMPlayer https://drive.google.com/open?id=12_v77JTTJcPjIyDkJi6CJMdyF-FWTay9&usp=drive_fs
Trouble DUDU-Meng I downloaded the link, installed it, and the problem was resolved. I hope it will be included by default in the next version. Thank you.
DUDU-Meng Trouble As long as the version number is higher than your current version, this feature will be retained.
