• Bug Feedback
  • Problem with FM radio
DUDUOS_DUDU7862_Global_240731 The radio application does not remember the last FM station you listened to . It remains on the lowest frequency, so every time you start the car you have to manually change the station.
    wybitny2
    If the power is cut off and then reconnected to restart the device, this situation will occur.
    Under normal usage conditions, such as restarting the device or entering sleep mode before restarting the device, this issue will not occur.
