Battoussai Hi. As the following attached photos show, the open car door status is not present on main menu/desktop. If I go to Phone Menu or Settings Menu, the open door status is displayed. On previous 3.6 version of 25/08/2025, it was working. Car is a VW Golf from 2011. There is also a member on the forum with same question but on a Mazda from 2006.
DUDU-Meng Battoussai Are you using the minimalist mode where one of the plugins includes a car model with door-opening animations, but you dragged that plugin to the side to hide it? If so, this is normal behavior—it's designed that way. If you don't use the vehicle status plugin, you can disable it to make the home status pop-up appear.
Battoussai DUDU-Meng Thanks for the reply. I'm using minimalist mode but without the car model. Nevertheless I will disable it, as recommended, to see if it helps popping up on main screen.
DUDU-Meng Battoussai Minimal Mode has three plugins. Take a look at the hidden plugin—does it have a car model with an animation for opening and closing the doors?
