• Apps mainscreen instead of mini widgets
Hello everyone.
Is there a possibility to disable the widgets on the mainscreen and select apps to put on the mainscreen instead?
I and i think a lot with me would like that very much because that makes it easier to use when driving.
Regards, Arjen
You mean, you don't want this part.
    DUDU-HUANG
    Yes, in my case the widgets on the bottom instead of left but i don't use the widgets.
    i like to place apps directly on the frontpage.
    DUDU-HUANG
    I also need the ability to hide these widgets.it is possible to do this both for the navigation bar. open and close by gesture. Can you do that?
    DUDU-HUANG
    Yes that part, if it is on the left or on the bottom. So you can choose zero and not a minimal of 4. Also it would nice and on most headunits in the market normal that you can choose your own apps to put on that page.
    Regards Arjen.
    This will hide the message in subsequent releases!
