DUDU-Meng In Hungary all service providers have shut down 2G and 3G, and what still works is 4G — but mostly only for data — and LTE.
5G is a complete mess in this country, and I don’t even want to use it. Hungary Mobile Network Frequency Bands (2026)
Technology Telekom Hungary Yettel Hungary One Hungary
2G GSM 900 MHz (B8), 1800 MHz (B3)* 900 MHz (B8), 1800 MHz (B3) 900 MHz (B8), 1800 MHz (B3)
3G UMTS Discontinued Discontinued Discontinued
4G LTE B1 (2100), B3 (1800), B7 (2600), B20 (800) B1 (2100), B3 (1800), B8 (900), B20 (800), B28 (700), B32 (1500 SDL), B38 (2600 TDD) B1 (2100), B3 (1800), B7 (2600), B8 (900), B20 (800), B28 (700), B32 (1500 SDL)
5G NR n1 (2100), n28 (700), n78 (3600) n1 (2100), n28 (700), n78 (3600) n1 (2100 DSS), n28 (700), n78 (3600 - limited deployment)
Frequency Band Reference
Band Frequency Usage
B1 / n1 2100 MHz LTE / 5G DSS
B3 1800 MHz LTE Capacity Layer
B7 2600 MHz LTE High Capacity
B8 900 MHz GSM + LTE Coverage
B20 800 MHz Primary Nationwide LTE Coverage
B28 / n28 700 MHz LTE + 5G Wide Area Coverage
B32 1500 MHz SDL LTE Supplemental Downlink (Carrier Aggregation only)
B38 2600 MHz TDD LTE TDD (Yettel only)
n78 3600 MHz High-Speed 5G
Notes for Android Head Unit / Modem Developers
3G (UMTS) has been completely shut down in Hungary by all mobile operators.
LTE Band 20 (800 MHz) remains the most important band for nationwide coverage, especially in rural areas.
LTE/NR Band 28 (700 MHz) is becoming increasingly important for both LTE and 5G coverage.
Band 32 (1500 MHz SDL) is Supplemental Downlink only and cannot operate as a standalone LTE band. It is used exclusively for Carrier Aggregation.
Band n78 (3600 MHz) provides the highest available 5G throughput.
One Hungary primarily uses NSA (Non-Standalone) 5G with DSS, while Telekom Hungary and Yettel Hungary also operate Standalone (SA) 5G in parts of their networks.
Since 2026, Telekom's 2G service has been provided through Yettel's radio access network, so devices should not assume an independent Telekom GSM infrastructure.
Carrier Aggregation (CA) is widely deployed by all three operators. Devices supporting 3CA/4CA will achieve significantly better LTE performance.
For automotive Android head units and LTE modems used in Hungary, support for B1 + B3 + B7 + B8 + B20 + B28 + B32 + B38 (LTE) and n1 + n28 + n78 (5G) is strongly recommended for maximum compatibility.
