ashuqair Hello team, I just wanna ask for DUDU3/4 compatibility with my head unit, so i can install this awesome OS. I have Chery Tiggo7 2025 (Egypt version), and this is my FYT device info: Thanks in advance.
ashuqair Hello team, I do not have a firmware backup for my winca device, so i do not wanna risk. I will be grateful If you could advise regarding my device specs with DUDU3/4.
Mikescotland ashuqair android version 15?? Unlikely it's 15. So take other specs with pinch of salt as well.
Pavel-71 ashuqair There is a solution, you can backup your unit. Read, learn, have fun. Good luck. https://xdaforums.com/t/general-fyt-based-spreadtrum-uis7862-s-unisoc-ums512-uis8581a-sc9863-q-a-mods-tips-firmware.4396339/#post-86349167
Mikescotland ashuqair you can try but bear in mind you can brick the device and you don't have the firmware for it. Technically it should be possible to instal on it. In practice, I don't think even Dudu will give you a decisive answer.
