hadious Hadious, can you test if the videos that are not playbable in DUDU 7, can be played correctly on your PC/laptop. For me it seems that they can be played ok without problem on my PC... I will test again at some point, but from what I saw, the recordings are playbable on the PC. For me the DVR application has a lot of bugs... The DUDU team needs to implement a driver so we can access the videos of microSD from the File Explorer.
At the moment the videos are downloaded and stored in the internal memory of the DUDU 7. That is very insufficient because it consumes the internal memory of the headunit... The videos should be playbable directly from the memory card, maybe with a small buffer on the headunit that is flushed out after the video is closed...
