Klein509 what do you mean? Perfect signal and accuracy on DUDU. Is that wrong?
If you refer to the strength of signal of satellite 26, this is also perfectly normal. Measures 3 minutes away, satellite moved over you dozens of miles across the sky. Also signal can vary as antenna of your phone and of Dudu are not in the same position.
