  • POP sound at boot DUDU6
At every boot, DUDU6 or M6 Pro (two different devices, two different cars) with DUDU OS make POP sound from the speaker. It's quite loud and disturbing. It wasn't on original Mekede firmware, only on DUDU OS
DUDU7 seems to not have this problem.
2 months later
hey @DUDU-HUANG @YAOXILONG how about this case 🙁
21 days later
Same here on a Mekede M6 Plus 3D. Didnt' happen on the original firmware.
The sound is even louder if you press the reset button. My car has a BOSE amp so I'm using the RCA pre-outs. Maybe it does not happen to those using the unit's internal amp?!
    suicidalguitar yep happens without external amp also with my Mekede m6 3d 7862
    I, too, can report having the same unpleasant pop sound upon booting the system. I have to mention that my car has an OEM stock external amplifier so that I had an issue with constant humming noise already on the m6 3D firmware by Mekede. Therefore I use a special hardware equalizer to decrease the gain for each of the four channels to minimize the noise.
    Still, the pop sound very rarely appeared before switching to DuduOS 6.
      HondaCivicDriver
      What hardware equalizer are you using and how effective is it? Same issue here and I'm trying to figure out the best way to eliminate such noises. The noise reduction setting on the unit works ok, but I'd say about 30% of the humming/hissing noises are still there.
      I'd like to try something to convert from the SPDIF out to the line level input of the car's amp, but not sure if there are such device that won't cost the same or more than the Android unit itself.
      There are also High to Low level converters but good ones are not cheap and I'm convinced that taking advantage of the digital output of the unit would be a much better opiton.
      What's everyone approach on these cases when there is an OEM or aftermarket external amp in the car?
        What I use is this one:
        https://incartec.co.uk/product/ISO-to-ISO-amplifier-integration-interface-cars-with-original-amplifier-20-273
        Price: £33.33 (£40.00 inc VAT)4 channel adjustable ISO to ISO amplifier interface.
        Use to install a new radio in a car that has an original fit amplifier that takes a pre amplified audio feed.
        This interface converts the high level audio output of a new head unit to a low level pre amplified signal which will work with an amplifier.
        4 adjustable channels for optimum audio quality, it has a built in ground loop isolator and filters to get the best sound from the amplifier.
        It is pretty much effective, I used a screwdriver to minimize the gain per channel and even if reduced as much as possible, I could still hear a very small noise from the left front speaker. You can only hear it in a standing car, and only with good ears , so most persons did not even notice it.
        suicidalguitar
        "There are also High to Low level converters but good ones are not cheap and I'm convinced that taking advantage of the digital output of the unit would be a much better opiton."
        Do not mind that. I am very delighted with the sound quality improvements due to the DAC - amp combination of my radio m6pro tied up with this hi-lo-converter. I play Tidal directly and lossless from the app. I would say it is night and day compared to before...
        If you want to read even more about setup you can check this forum:
        https://www.civinfo.com/threads/successful-install-of-chinese-android-unit-in-2014-tourer-with-nav.432426/page-2
          HondaCivicDriver Thanks a lot for your detailed answer.
          If you still ear some noise, it might not solve my issue because what I ear in my system is also not noticable to everyone and only when the music is at low volume and soft, which with my blues/rock/metal playlists is not usually the case 😅 The POPs however are quite loud and noticeable by even my deaf grandmother.
          But your tip reminded me that I have a similar adapter from a previous instalation in another car. Something from Connects2 which should be of good quality. However connectors are not compatible. I'll give a look at the schematics and maybe I can make it work. But I would still like to find something that would allow me to use the digital output (spdif or coaxial) and convert it to analog low level signal that can feed the Bose amp. That's a nice feature of these Mekede M6s. I just need to find how to use it.
            14 days later
            suicidalguitar
            Just as an update, I did manage to use the Connects2 harness I had in storage for 7 or 8 years. Bought it for tablet + Sony old school 1Din radio install on another Audi TT I had before, so I was up for a good start.
            Tested it for the sound quality and straight away what a difference. I was not expecting a Hi to Lo converter that did not cost me an harm and a leg (although I must admit I can't rememeber how much it was) to give me better sound quality than using the low level RCA output. The 30% of the humming/hissing noise that was still there is now gone. The sound quality has dramatically improved. I was kind of happy with it before (apart from the noises at low volume), but now I am truly amazed. Much closer to the CD quality of the original headunit.
            Unfortunately the CANbus was not compatible with the FYT unit. Connectors were totally off. But I was so amazed with the sound quality improvement that I had to find a solution. So after what felt like an eternity staring at both harnesses (FYT and Connects2), and both CANbus boxes, I decided to try a transplant. In my mind it was making sense so I took the risk. It felt like an open-heart surgery. Guess what?! It worked the first time.
            This headunit never ceases to amaze me. Huge improvements after installing DUDU, followed now by a huge sound quality improvement.
              suicidalguitar great story and I am very happy that I could contribute a tiny bit (I hope 😅😎).
              Actually my hi to low converter from Incartec also comes with a ground loop isolator to prevent interferences. Maybe that also ameliorated the sound a little. I mean in hifi environments people do care about copper cables, isolators and whatnot.yet here we are cramming all cables and antennas and stuff randomly into our dashboards just to make them fit into that little space ..
                Ich habe ein Störgeräusch im Subwoofer, wenn der Lüfter vom Radio angeht.
                Es wäre besser den Lüfter und die Steuerleitung vom Verstärker zu trennen.
                Wenn ich den Lüfter abstelle, ist das Geräusch weg.
                HondaCivicDriver you did help. That's also what these forums are for after all.
                This mess behind our head units is the worst nightmare of an Hi-Fi enthusiast 😅
                It's a never ending job for us head units enthusiasts though. For now I'll leave it alone as I'm in the process of moving job, city and house (and the 2 little girls also need attention), but I'm aware there are many useless cables that can be removed/cut off. Starting by the RCA that is now useless. SIM card reader is in the same connector otherwise it would already be out. A good idea would be to remove those pins from the connector.....Damn!!! Now I want to do it 😫🥴
                5 months later
                • Edited
                I'm a new user of Dudu6 OS 7862 beta with a Mekede M6 Pro Plus. It is giving the audio pop on reboot. It didn't give this pop when it used the Mekede firmware. My head unit connects via a wiring harness into my Mazda CX5 stock sound system.
                Perhaps it is due to the amplifier being turned on before the stereo head unit has booted up properly?
                Did the Mekede OS mute or create a sound or amplifier delay when the device is rebooted or booted up?
                  a month later
                  Same here with dudu7 headunit, subaru outback harman kardon oem amplifier pops loud on boot. any solution to this issue? also my volumen is insanely high, like level 5 is already loud out of 40 volumen scale, is there any where to lower the sound output power? on the dudu 7 software? thanks for any help. i just dont want to accidently blow my oem speakers
                    McDudu see here
                      picasso1850 Thank you for the link, i would give that a try, one thing i am wanted to confirm is if you ended up having to take your headunit off to connect the AMP control wire to the AMP CONT on the A connector of the radio? or just installing this apk solved it alone! thanks again for answering to my help call.
                        Rev Before installing Dudu 6 Beta I had the latest Mekede m6pro 3D firmware and I also got the pop sound on reboot.
                        McDudu I didn't, apk only, but engage the admin that started the thread since im not an engineer and do not know the difference between your wiring / canbus configuration and mine.
