DUDU-Meng Please manually install this APK file to test it. Restart the system after installation. https://drive.google.com/open?id=1LsFV6hcLisE-uUvyaSJiDDZKlUHbSvw6&usp=drive_fs
Popescu DUDU-Meng I Install the apk. Is ok if the speed is in change(it show protocol speed) . If i drive on autopilot (constant speed) , the speed drops with 4 km/h (GPS speed), if i change speed it show protocol speed.
Popescu DUDU-Meng Yes i Install. Is solved partial. Is ok if the speed is in change(it show protocol speed) . If i drive on autopilot (constant speed) , the speed drops with 4 km/h (GPS speed), if i change speed it show protocol speed.
Popescu DUDU-Meng i made a video. https://drive.google.com/file/d/1gVwoDpap8Ys67jAKp9h5Mw5AMIsJ0fGY/view?usp=drivesdk
DUDU-Meng Popescu I have submitted access permissions, please allow them. Are you saying that it has two speeds when driving on the road?
DUDU-Meng Popescu The previous logic was not to repeatedly send speed information when there was no change in speed, but now it has been changed to always send. Please install this APK https://drive.google.com/open?id=1DBYAOuzW3dzoaCqmHJhL7T9KkWU42zOV&usp=drive_fs
Popescu DUDU-Meng Hello! I Install apk,i restart. Is the same, i send a video. https://drive.google.com/file/d/1ggDDOy3Muq7KNyK20tcKL2LA2Ffi3yPj/view?usp=drivesdk Thanks
DUDU-Meng Okay, please test this APK. It should solve the problem. https://drive.google.com/open?id=1UCHlHAp-Y58pJLDiCJVQBVJz14qznN5u&usp=drive_fs
