Hi
I would like to check if there is CANBUS support for the 2011 Mazda Axela. The original head unit looks something like this:
The car did not come with the original unit installed but can confirm this was the unit installed previously. The unit currently installed is a JVC unit. The OEM wiring has not been altered in any way as the previous owner used a harness.
There are other units such as Eonon and Ainavi that support this car's CANBUS protocol using a Raise CAN box (unsure what box is provided exactly) so I'm thinking it should work with a DUDU unit as well, assuming there is a CAN profile for this and/or similar car.
The following features are known to work with a Raise CAN box and 2010-2012 Mazda 3 CAN profile:
- BOSE audio (this car does not have the BOSE package but the non-BOSE 6 speaker set up)
- A/C controls as long as the car has automatic climate control (this car has dual auto climate control)
- steering wheel controls (this car has OEM SWC installed)
- driver information screen (normally displays music such as track name, duration, FM/AM info)
- screen brightness dim/change to dark mode when headlights on
If someone has installed a DUDU unit in this (or a similar) car, please let me know if these features work.
@DUDU-Meng or @dudu-lai are you able to share the list of CAN profiles for Mazda vehicles available on the unit - both Raise and HiWorld. Also please confirm if these functions will work with DUDU.
If you need any more photos, please let me know and I will try to get them as soon as possible. I am installing this unit in a friend's car so do not have access to it right now so may take a few days.
Thanks
EDIT: The following are photos of the connectors from the actual car
