MihaiFlorin jgsolo32 You have to extract the archive on your computer's hard drive and after that copy the files to the root of the USB drive. I just helped a friend to update to 3.6e yesterday and everything went smooth. You should have 5 items on your USB drive (2 folders and 3 files). You have a picture attached on how your USB should look when you open it. Hope this helps.
ElevatedVehicles MihaiFlorin this is precisely the way just as Mihai said. And making sure that your USB drive is formatted to FAT32 If you put the zip file on the USB stick and then unzip it, it won't work.
ElevatedVehicles DUDU-HUANG Thank you for working with customers so fluidly. I tried for 2 years to help Joying fix their issues and finally gave up this year. It's so nice to meet with a head unit manufacturer that has great technical support and wants to grow the company. Thank you for everything.
ElevatedVehicles MihaiFlorin thank you so much for the suggestion on telegram! I'm happy to help many people π
ElevatedVehicles hrotkuc hello ππ» far East from USA happy it is helping so many from around the world my friend.
jgsolo32 ElevatedVehicles initially to format the usb drive, i have two choices NFTS or exFAT. i've tried both exFAT won't work. i can't move the files over just the main file "Global". when i choose NFTS, it will download on udud OS but I get an error.
UnagiC8 jgsolo32 Just use diskpart to format in FAT32 https://learn.microsoft.com/en-us/windows-server/administration/windows-commands/diskpart or https://guiformat.com/ NTFS won't work cause it's journaling file system developed by Microsoft. exFAT should work fine, but if not, then try FAT32.
Pavel-71 jgsolo32 You probably have a large flash drive, FAT32 formatting is only possible up to 32 GB in Windows.
surfer63 jgsolo32 You can format bigger usb disks with fat32 using powershell or the free 3rd party tool Fat32Format. Google for it how to do it. Or use something else than Windows.
ElevatedVehicles johnnyb_aus Here is the link to the beta https://forum.dudu-auto.com/d/1811-duduos-36e-public-beta-released-elevate-your-in-car-experience-250708/24
robdx2 ElevatedVehicles Thank you for replying anyway, great video @DUDU-Meng @DUDU-HUANG @dudu-lai can you tell us what voltage correction in the Lab debug settings is for?
DUDU-Meng robdx2 If your actual voltage and the displayed value are inaccurate, you can adjust the +- compensation here to ensure that the displayed value matches the desired value.
