dudu-lai Depends on the OEM screen, whether or not you can manipulate the air conditioner as well as the setup items
jgsolo32 dudu-lai this display unit is the 13.3 " duduauto 7 12gb ram 512gb storage. Is this what you mean by OEM screen?
dudu-lai jgsolo32 When the original host screen supports air conditioning and setting items, the CANBUS box will parse the relevant instructions and codes, and DUDU can control
jgsolo32 dudu-lai and that's is wjere I am at Its not working on the dudu screen. AC/heater does work using car buttons but n I t on the screen It says on the screenshot "ac not supported"
dudu-lai jgsolo32 If the original host screen does not support air conditioning control, then DUDU does not support it either. If the original host screen can control the air conditioning, then DUDU can also. Can you confirm this?
jgsolo32 dudu-lai thanks for the clarification. I did not understand your previous response and now I do understand. I dont remember the oem screen having on screen controls and therefore it won't be usable amd just visual on the dudu screen. Thanks
