The text displayed on the screen was too small, even after all of the size relevance setting. (on a 9.5-inch 2K resolution device, DuduOS 3.6)
So I referred to this forum and modified the 'lcd_density' setting in the config. (https://forum.dudu-auto.com/d/747-screen-size)
After the change, the text size was adjusted when running individual apps, which made it more convenient to use.
However, this change does not apply to the Dudu Launcher PIP. As mentioned in the forum comments, so I was aware of it.
Therefore, I would like to request an improvement to the PIP text size adjustment feature.
- Normal mode: Add an option larger than the current “large”, or allow users to input custom values directly.
- Minimal mode: Add a text size adjustment setting (same as the improved normal mode).
Surely some of apps might not be seen properly with these feature, but I think user should be able to adjust app display setting which they want to use in the basic windows as well.
Thanks in advance and your sincere efforts.
