• Update Bulletin
  • DUDU Launcher for DUDUOS Update Highlights and Release Notes
anpandiyaraj Oh yes i can. It is really loud on level 7.
Made two calls to our answering machine. And i was really surprised.
I would love to have this for the DUDU7 to.
YAOXILONG changed the title to DUDU Launcher for DUDUOS Update Highlights and Release Notes .
720 기기에서 76버전 pip1 <-> pip2 전환후 ui가 커집니다.
    JhonnyD It would be good if in general you could see everything bigger. I have tried to decrease the dpi from developer mode in the smaller width option, but it does not allow me less than 735 DPI.
    5 days later
    Bản này cài trên teyes 2k bị lỗi pip
    Will we be able to change the 3D car model?
    20 days later
    Hello, I recently acquired a Dudu7 8G 128G, I cannot change from °C to °F and from 24 hours to normal hours. Thanks for the help.
    a month later
    Will the launcher be updated here or in the store app? The version currently in the store is older than the one that comes with DUDU 6 test 19
      SDenKrUA если в магазине есть доступные для обновления приложения, необходимо их обновить. Опубликованный здесь лаунчер также был доступен в магазине приложений.
      I upgraded my mekede m7 (mekede shop) from 2024-05-23 to 2024-07-26 and there are many problems like.. The yellow line above says( UI and MCU does not match!(LSDD)
      How can I fix it? Can I go back to the previous version?
        sakisdid By installing the stock firmware from Mekede back. DUDU OS works only on 7862 devices, and only if you are enlisted as a beta tester. It will never work on 7870 devices. So install the stock firmware from Mekede for M7. To have DUDU OS on 7870 you have to buy a DUDU device. I hope I was clear enough.
        4 months later
        DUDU-HUANG unmarked the discussion as super sticky.
