Yhs70 dmitry356 did you just update using usb or turn on off any other setting to hide navbar? Mine is not hidding in 360app
DUDU-Meng Yhs70 The function is to quickly hide the navigation bar when turning 360 degrees and shifting into reverse gear. There is no delay.
Yhs70 DUDU-Meng do i need to turn on the hide nav bar option in settings? and how to install this app
DUDU-Meng Yhs70 I just noticed that after uploading the APK file, it was automatically converted to ZIP. You can change the extension back to APK yourself.
Yhs70 I already downloaded it. Just tell me how to install it? I copied the zip file on usb. When opening through dudu file manager its saying to extract it not install
DUDU-Meng Yhs70 Just change the extension to apk. The forum does not allow apk uploads, so it will automatically rename it.
Yhs70 In future updates do i need to do this again or will this remain? Or if i factory reset will this setting stay or not
DUDU-Meng Normally, it won't change, so you can save this app. If there are any changes, just do it again.
