Yhs70 I got an error. After inserting usb it said new firmware detected and then it restarted then i got error. Picture attached
Yhs70 DUDU-Meng please tell me about error? It’s not working. I unzipped all files to usb and it just gave error. 360app still showing navbar
Yhs70 dmitry356 did you just update using usb or turn on off any other setting to hide navbar? Mine is not hidding in 360app
DUDU-Meng Yhs70 The function is to quickly hide the navigation bar when turning 360 degrees and shifting into reverse gear. There is no delay.
Yhs70 DUDU-Meng do i need to turn on the hide nav bar option in settings? and how to install this app
DUDU-Meng Yhs70 I just noticed that after uploading the APK file, it was automatically converted to ZIP. You can change the extension back to APK yourself.
Yhs70 I already downloaded it. Just tell me how to install it? I copied the zip file on usb. When opening through dudu file manager its saying to extract it not install
DUDU-Meng Yhs70 Just change the extension to apk. The forum does not allow apk uploads, so it will automatically rename it.
