DUDU-Meng I finally figured it out. When I was creating the jump drive I didn’t pull the files out of the sub folders first, so all that was on the jump drive were strictly files and the compressed bin file. I think maybe that should be updated in the instructions that are given on the forum for beta updates and patches like this, because the way it’s described is that all you have to do is extract the 7z file to the jump drive and you’re good to go, which that’s not the case. As far as if the update worked, I’m not sure yet. I had to get all my settings back the way I wanted them first tonight, which took a little time. So tomorrow I’ll check to see if FaceTime audio calls work, and then give you an update on whether it worked or not.
