Harmlex Заказал dudu7 8/128 Вопрос по подключению. Штатная камера 5 вольт. Могу я использовать и настраивать выходы из разъема B. 360 Panorama camera . Под питание задней и передней камеры там два выхода 5v. Без подключения боковых камер? Как можно подключить штатную кнопку wiev включения только передней камеры? Автомобиль Toyota
dudu-lai Toyota OEM 360 imaging? Is the problem you are facing now that there is an image when reversing and the VIEW button does not work?
Harmlex dudu-lai After reviewing the entire connection diagram, dudu7 could not find where to connect the wiev button.
Harmlex dudu-lai there are connectors with descriptions on the back of dudu7. I couldn't find where the view button is connected in this description. the key input is used for the roulade buttons. I couldn't find inputs for the view button.
Harmlex dudu-lai I don't understand why I need an app on the device if I want to use the standard car button to turn it on. I can't find where to connect it according to the diagram.
dudu-lai Harmlex I am also talking about the OEM button (VIEW) Have you tried the method I mentioned?
