Ojika
The setting you mentioned is the DPI adjustment, since the value has been fixed in config, you can only change it here for the current time, and the next time you turn on the computer, it will revert to the default.
If you have to fix the DPI, you can use the generic DPI modification script, fill in the number you feel is appropriate, and use a USB flash drive to upgrade.
