CHR12345
The problem is caused by reading USB devices.
On the 7862 device, if you first connect CarPlay via cable and then connect a USB device, such as a USB drive, you will not be able to read the USB drive.
If you connect the USB drive first and do not unplug it, you will no longer be able to connect CarPlay through wired connections.
This issue will not occur on the 7870 device.
Media APP disconnected CarPlay via wired connection to ensure that you can read the songs on the USB drive.
Other applications, such as other music players, do not disconnect CarPlay through wired connections and cannot read USB drives.
