  • Add support for SimpleSoft RP5-SU-001/SU-SS-01 Canbus Decoder
[Moved this thread from the DUDU OS section]
Hi,
I've installed a DUDU7 headunit in my Subaru Forester 2016 XT with a SimpleSoft RP5-SU-001 Canbus Decoder as my trim has a Harman Kardon sound system.
Although some of the functionalities are working fine (speakers, backup camera) , the assignment of the steering wheel controls is not correct & also the headlights are not being read by the OS; the day/night theme is not controlled by the car.
After doing some research, it seems like DUDUOS 3.5 is not supporting the SimpleSoft RP5-SU-001 Canbus Decoder. In a competitor's website where they sell this Canbus decoder, they do list the type of decoder to select, which is not available in DUDUOS 3.5:
Is there anyway for the support of this decoder to be added? Let me know if you knew more info; I'll be glad to help.
My regards,
    If you go into canbus vehicle settings and select Type 1 mine was set to type 2 when i first got it and had the same issues as you are having.
      UK_mook
      Hi. This solved the issue for most of the streering wheel controls! The menu button doesn't do anything but that's okay for now. Big Thanks!!
      Another thing: the Night/Day themes still can't be controlled by the car through. Where you able to make it work?
        I have an outback 17 so it’s probably a bit different, but yes it can but I don’t bother I just use the night day button, as it’s annoying if you need lights on in the day time.
        falstaff In “Android Settings” - “Display” - “Backlight Control”, is it the light or the time that is selected?
        It needs to be selected as light
          dudu-lai it is set to "Lamp". There's no "Light" in that menu:
            falstaff
            Already set to light
            In “Settings” - “Desktop” - “Day/Night Switch”, select “Light Switch” and set the “Day/Night Theme”.
            If it does not take effect, measure whether G4 of the DUDU G connector is connected to the light switch.
              dudu-lai
              I've already tested setting the “Light Switch” to “Day/Night Theme”. It has no effect. For now I manually use the Day Night button as recommended by @UK_mook.
              G4 is connected to the Canbus decoder. See the green line I've drawn in the photo below:
                falstaff Can you measure if there is a switch cable for the lights on the stock connector? Connect it to G4.
                4 months later
                falstaff
                Hi, did you get the the Dudu7 to display door opening etc (Car data)? everything else works.
