hello everyone I just installed duduauto 4 on an opel zafira c tourer the problem is that the car radio when I turn off and lock the car always stays on and does not turn off can someone help me solve this problem how can I turn off the car radio when I lock the car please
Car Radio Shutdown Problem
Did you look into settings > Vehicle > Startup > Head Unit Startup Settings?
"No, I don't know what setting I have to go to.
"Unfortunately not, because I don't know what setting this option is in."
Enzo88 It seems as you don't want to be helped. Provide your system info please.
I purchased the Dudu 4 10 inch model car radio from AliExpress today I installed it in the car with the canbus module the car is an Opel Zafira c tourer the car radio works correctly the problem is that it never turns off I turned off the car removed the ignition key from the car and closed the car but the car radio always stays on I can't turn off the car radio I would like to know how I can solve this problem if there is a setting in the menu to enable the car radio to turn off
this is the car stereo model
Enzo88 Man, I totally understand your frustrations. But you have to read what people have written above. There is a link that I posted where is very clearly explained how to provide your system info. If you don't want to do this, why should others bother to help you? You must want to help yourself first. The fact that you have a Dudu 4 doesn't say all about your device (maybe 20 percent). There is firmware version, CanBUS adapter and so on.
