• DUDU OSFunction Request
  • Carlink WIRED
Can the Carlink CarPlay app do wired connection? Sometimes the wireless connection fails and also want to charge phone, is there an option to do wired CarPlay?
    Tswire Yes the 4 pin USB supports wired CarPlay/Andrpid Auto.
    Supports wired links
    But must be linked with a 4ping USB port
      DUDU-Meng
      Thanks. Just figured that out however, it attempts to connect to CarPlay and never connects. “Verification approved” appears then it repeats. Hmmm
        Tswire this happens with iPhone 13 pro max on my device as well. There's nothing except "verification approved" message. I don't own an iPhone, but my android works well. Tried iPhone 13 Pro Max and XS without success.
        Tswire This problem happens just for the first connection, just try to reboot the head unit and then try to reboot your iphone also try to disconnect the wire then reconnect it, it will work just need some patience and don’t worry this will happen just for the first connection by wire but later it will not happen with you
