Hello,
I have installed the 360 cameras on my dudu7 12g/512gb system, but it is not triggering the backup camera when I put in reverse.
The trigger wire from the 360 backup camera was wired to a 12v+ at the backup light and I have checked connection with a multimeter that I am getting 12v to the trigger wire when in reverse.
At the head unit, the trigger wire is not connected to G5 since I have a Simplesoft RP5-CH-004 canbus for my 2015 jeep wrangler.
I believe the wiring should be correct this way as I have searched for answers on this forum.
Could this be a canbus settings issue? or could it be that the canbus doesn't support reverse detection?
By the way, my 2015 Jeep Wrangler is a MANUAL 6 Speed Transmission, so not sure if it matters for canbus reverse detection if it is a manual or automatic transmission?
How can I get the 360 backup camera to trigger when I put on reverse?
Should I try to wire the trigger wire at the head unit to the G5 connection even though I have a simplesoft canbus to see if it works?
Please see my system info below:
