Message received
This will be fixed in the next version
Incoming/outgoing calls display no contact info
okay thanks,
I changed '1-541-887-xxxx' to '+1-541-887-xxxx' and incoming/outgoing calls seem to work now, just need correct formatting.
Is there a way to remove or change the Chinese character in front of the time? I think that character translates to 'morning' could we get an AM/PM possibly?
https://drive.google.com/file/d/1nkVn7n6h4oKwGgJZVAiErJesoRLYach_/view?usp=drive_link
It can be deleted. The next version of Bluetooth phone will fix this bug.
Please install this application manually to test the recent call logs Name display issues
After you install the latest version, you can use this icon to update and sync your contacts to prevent the previous data from affecting the display.
sorry for the late reply, I was trying to install it. I have no idea how to install it.
I put the apk on root of a flash drive formatted in fat32.
I copied .apk to new folder 'btoothupdate' under local.
I tried localupdate under bluetooth update and got "Incorrect update file selected, please choose again":
https://drive.google.com/file/d/1iMP2MtcrtaAeIDydY1y2Vsf0sluq2gwl/view?usp=drive_link
I tried to run .apk directly and got "APK information unavailable".
https://drive.google.com/file/d/1MH_IpwGZFmOEq_tAZsaFbDLIYEv9zqaR/view?usp=drive_link
I clicked local update and it flashed my version to CQ134_LSDT_V2.0_2025-03-20_10:01:43_blink131(Jul 5 2024:16:54:07)
https://drive.google.com/file/d/18l93EP6d2Ec88C5T8usTVZfJDDdUU2ZN/view?usp=drive_link
this was not the apk you provided, need assistance on how to flash that .apk. My unit is Dudu7, i'm unsure if a 7870 firmware will work? thanks
The file size is 16 megabytes.
It's an APK file. Install it manually.
I tested this with the following numbers:
a google voice number: +1 541-887-xxxx
my sons main number: +1 541-880-xxxx
and my number tethered to unit with Bluetooth: +1 541-591-xxxx
I changed the formatting for 3 different tests in my contact info for these numbers. The first test I used the following formatting for the incoming numbers:
(541)887-xxxx
(541)880-xxxx
this formatting showed the name on both incoming calls, but the picture in contact info did not display.
https://drive.google.com/file/d/1oUBUpY9srUZjqCdlxMpDBUCe7bXSG-S6/view?usp=drive_link
second test with the following formatting:
1(541)887-xxxx
1(541)880-xxxx
this formatting showed the name on the 887 number for incoming calls(google voice) but did not show the name on the 880 number. Neither displayed the picture on the contact info.
https://drive.google.com/file/d/1kg0yxvW7rDXeZ39JySHWhpWFOHiYKBFE/view?usp=drive_link
https://drive.google.com/file/d/16CcNh5Fp5Qu55b-Zh6sekCyluFVT5jsz/view?usp=drive_link
last test with the following formatting:
+1 541-887-xxxx
+1 541-880-xxxx
this formatting showed names on both, and also showed the pictures on both.
https://drive.google.com/file/d/13x_urXLkg1UyU1agOjKzez21g3Q7uxo-/view?usp=drive_link
https://drive.google.com/file/d/1R9hmGtTrAmT1mBRPvHVlZ4rSf56acdA_/view?usp=drive_link
this is still an issue if using a format outside of +1 xxx-xxx-xxxx. But I changed all of my numbers in contact list to fit this formatting, so I have no issues now. However, if you sell units to people inside the USA and they do not have their contacts formatted in this specific way, they will encounter this problem unless they change their contact formatting to match the +1 xxx-xxx-xxxx.
The AM/PM formatting is better than the chinese characters, is it possible to move the AM/PM after the time, and put a space after?
https://drive.google.com/file/d/1ZphhTQwGRGPnUmJnCtZD5eUMRHonlFzj/view?usp=drive_link
I cannot dowload the apk
mazdamx5
issue with browser blocking the file, you need to allow the download.
https://drive.google.com/file/d/12AVuOfqwSOqR3PBOwPOOwYwdcXXA0k-s/view?usp=drive_link
I'll send it to Google Drive, and you should be able to download it just fine.
https://drive.google.com/file/d/1oQxQqOi2-cWJh2KnvtnOjDxwS0OQwKJJ/view?usp=drivesdk
