• Bug Feedback
  • VGATE iCar Pro Bluetooth 3.0/4.0 couldn't be paired
Hi Dudu team,
I bought an VGATE iCar Pro Bluetooth 3.0/4.0/Wifi OBD2 Android/IOS ELM327 V2.1.
It works with my HU and Torque app (pair via Bluetooth-pair-2.8 apk, someone share in telegram channel).
I couldn't pair via Android Bluetooth setting even see my ODB device in the list, it show text box to input the pin and didn't show anything after I input the pin code (1234)
This is my HU About info:
ODB bound menu doesn't see the Android Vlink(my odb device name). I tried to bound with IOS vlink but it didn't work also.
This is my device: https://s.lazada.vn/s.VetjB
I tried to update system with BlueToothFix ( Bluetooth type : 0, 1, 7, 8) but no luck.
Could you please help to take a look?
Thanks
    Попробуйте выбрать в меню duduos ios-vlink. Затем попробуйте выбирать разные варианты протоколов. Например youja......
    Предварительно спаривать с системой при подключении bt4 не нужно.
    Let me try. Thanks Chubaka
    I tried but i didn't work also
    Is it possible to add additional paring mechanism ( mimic the "Bluetooth-pair-2.8 apk" options ) if the paring device is doesn't support human interface ?
    Teppy
    Setup>Device>OBD>OBD Settings>OBD Category>ELM_327
    Try this
    With mtc platform it was possible to connect every obd.
    Now we have a 600 Euro absolute fast head unit and we have to buy verified obd.
    Why not make it better than other sellers?
    I thought DUDUAUTO makes their own universe but when i read all this what is posted everywhere, it is not better than any other FYT.
    You have all possibilities to make everything better than all other sellers. But you have to want to...
    2 months later
    I have exactly the same problems with connecting to ELM327 VGATE iCar Pro Bluetooth 4.0. Is there a solution to this problem?
    5 months later
    The same situation as ajakovlev
