  • Google TTS volume too low
MihaiFlorin Nope. Not this setting. There is another one.
  • Edited
This settings. Klangbalance.
    JhonnyD One option doesn't work, now I can't upload it because I can't upload photos on my phone.
    The option selected in the screenshot does not work. Dudu6 has no problem with this. In dudu7, selecting this option does nothing because it does not work. Dudu6, TTS voices from Google are quiet, clicking on this option causes a big change.
    JhonnyD You have it set wrong, the radio must be on 3, the navigation on 9 or 10. Then you can hear TTS voices, now as now you can't hear anything.
      • Edited
      wybitny2 the navigation slider does nothing in my case. I can set it to 0 or 10, nothing happens.
      If i set radio and or music to 3 i have to set the overall volume to 15.
      The DUDU team has to work on the overall volume.
      It increases not steady. From 1-6 it is good, then until 15 nearly nothing happens, then from 15-20 it is ok again.
      The whole volume story needs to be reviewed.
        Indeed the navigation volume has no effect. And just playing a sample message in the google tts settings menu is also too quiet. Even with the option louder checked (see picture in the message from wybitny2). So the problem i think is more related to google tts and not directly with a navigation app. The volume of the native navigation voice of Sygic (not the tts voice) is ok
          JhonnyD Before passing judgment, I recommend a factory reset. I think that sometimes you have to do it because minor errors appear.
            ismove I think it's unisoc's fault, I think if they improved this option the TTS voices would be louder.
            20 days later
            Are there any plans to have this fixed in the future? Since I cannot use TTS in the navigation app (Sygic) I only get vey basic navigation instructions
              wybitny2 Selbst nach einem Reset funktioniert das nicht.
              Zu dem Problem habe ich festgestellt, dass es nicht nur reicht, dass man angibt welche App als Navigationsapp dient, sondern bei mir hat es geholfen bei der Option weitere Apps zur zweiten Tonspur hinzuzufügen, dort auch noch die App anzugeben.
              Seitdem funktioniert das wunderbar mit TTS Stimmen.
              ismove I use Sygic and the TTS voices work for me, I can hear them without any problems, they could be louder, but they work well.
              9 days later
              I currently have a Motorola phone, previously a Samsung and this option checked does not work on any phone. The dudu os application has no error, only quiet tts voices from. There is an option to adjust them, but they are still quiet, they could be a little louder. I compare it to the FM radio app, they could be as loud as the FM radio app, then you could adjust them. Right now you have to set the FM radio to 3 and the tts voices from google to 9, then you can hear them. This is too small an adjustment. No matter what software version, it always happens dudu7.
              a month later
              I noticed that in this version the FM radio volume slider in the built-in voice control is at a lower voice level with the setting as in the photo. The problem is that in the case of tts voices from google navigation, sygic, the narrator is a bit quieter. This has been happening since the beginning, you always have to turn the radio down to hear the voices, in dudu 3.6 beta3 the narrator voices in sygic navigation are quieter.
