Hello everybody,
I just bought a new Dudu7 6g 64g unit with the new uis7870 cpu but cpu-z reports that the cpu is in fact uis7885 (no specs found).
Does anybody know what is the real cpu in this unit?
Also, everybody is praising the DSP- IMO it is modest because it doesen't have LPF. It only has HPF on both sides (it cuts the frequency above the value that you select but it is impossible to set it to allow below the desired value for subwoofer for e.g. to be able to run it in an 0-100hz range).
Thabnk you,
