Just a few things I think would be helpful to some people out there:
Make the slider for brightness from quick menu have more range of adjustment.
SWC volume up and down increment setting. Would be nice to be able to jump up by 2 or 5 instead of 1.
Add a half mute option to SWC that can toggle back to previous volume if pressed again before volume is adjusted
Add an up down left and right touch control to the EQ so you dont have to touch and slide for adjustments. Also display what value is currently set without having to touch and slide.
Redesign the HPF/LPF so you can see the target curve. Currently HPF and LPF are backwards and it's harder to visualize than having a target curve displayed.
Add an on boot (or SWC) programmable keybind macro setting (touch bind) Say I boot the device, I could have my apple music automaticly raise up the lyrics panel this way.
Add setting for remote amp turn on delay to eliminate pop.
Something that can't be done with the current release but would be very cool for say Dudu8, add a harness that has a couple built in relays that you can toggle on and off and give us 87,87a, and 30 to play with however we please. Would be cool to turn other aftermarket accessories on and off with an internal toggle or set up a PIN number starter kill.
Something that would work with current model is maybe a bluetooth relay box that has a built in app/widget. Maybe not for a pin starter kill though as I wouldn't rely on bluetooth for that 😛
