• Bug Feedback
  • Fm radio station logos problem.
The Dudu7 FM station logo does not appear on the bottom bar after engaging reverse gear and turning it off, the problem is clearly visible in the video. For the station logo to appear, I have to change to another station and return to the same one. Video uploaded to Google Drive. https://drive.google.com/file/d/13YCjvEVdSt526SlkMEga6RHyfDufMmO9/view?usp=sharing
    wybitny2 Are you using NavRadio? Or DUDU radio? Just curios. For me DUDU radio doesn't bring the name of the station in the NavBar
      MihaiFlorin The original dudu FM radio application. Everything can be set, the name is no problem, the FM station logo is also no problem. The developers have made the FM radio app so good that I won't use NavRadio anymore. What is missing is that the logo and name of the FM station load automatically.
        wybitny2 In Denmark the auto assign of station logos doesn't work. In Romania it works. They've promised to improve it. I envy you. 🙂 And I think this is the motive why I don't get the radio station name in the NavBar. If I manually assign a logo it gets displayed on the NavBar, But I don't get the name of the station On FM XX,Y - Local FM. @DUDU-HUANG maybe you can do something about it? 🙂
          MihaiFlorin You can enter the name of the station yourself and I will show you tomorrow in the video.
          wybitny2 I totally understand you, but what's the use of this setting then? If you use it, you don't have to manually input the name for every station.
          The logos that you see in the background are manually assigned.
            MihaiFlorin
            Hi,
            How do you manually assign radio station logos?
              MihaiFlorin This option does not work for me, so I assign the station logos myself, and the station name as well.
                kolarov I can record a video to show you how to set them up, provided you have the FM station logo.
                  wybitny2 This is too much work, my friend 🙂 If you need to make a factory reset you'll have to do it all over again. That's why even if I don't listen that much to the radio, I still prefer the NavRadio+. The logos are assigned automatically and the name of the station is displayed in the NavBar.
                    MihaiFlorin Takes me a while. I prefer the original FM app because I like testing, and this one is perfect for that.
                    wybitny2 Yes, I have the radio FM station logos, but I couldn't see how to assign them to the FM stations
                      wybitny2 Thank you very much. The interesting thing is that in my case, after I give it a logo for a certain station, it doesn't save it, but shows another logo for another station.
                        kolarov From what I know, station logos should enter automatically, although not all of them. I have no problem and I can assign each station logo myself, but I don't know what it depends on. Since there is such progress, I think it will be better and better, it's a pity that we don't know where the station logos are and whether it's possible to add them to the file yourself. Turn off the internet, add the logo, check if it went in, then turn on the internet. Maybe you don't have the right logo and that's why it changes for you, I don't know how to explain it to you. I have a question if alternative frequencies work, because I have the impression that they do, but the display does not show another frequency, and yet the radio receives. That's what I noticed in dudu7.
                        11 days later
                        wybitny2
                        Okay, we will handle this issue.
