Prav___ I'd like to know what kind of hardware I need to integrate proximity sensors to my dudu7. My car doesn't have one at the moment. Thanks in advance 🙂
dudu-lai Sensors that can be connected to the CANBUS communication serial port on the back of the DUDU7
alikhan Help for recommendations for Paking Sensors !! Canbus will be occupied on dudu7 unit. 10.36 screen with 360 Camera There is teyes brand will it work? "TEYES Front & Rear Parking Sensors / Radars For CC3 / CC2 Plus" https://m.alibaba.com/x/xv9EINC
dudu-lai alikhan Have you asked the seller if the radar sensor is compatible with the FYT7870 or 7862?
alikhan dudu-lai I have, but he recommended waiting until my kit arrives. However, he did mention that it is generally compatible. So, I am waiting for my Dudu7 kit to arrive. Then will do next projects i.e integrate parking sensors
alikhan The seller advised me to contact TEYES, and guess what their response was? They said it would only work on a TEYES head unit. So now I'm out of options unless I install the OEM ParkSense for my vehicle, which is a bit of a setback.
dudu-lai Mikescotland No. Third-party radar sensors must be connected to the device via the CANBUS TX/RX port of the C-connector. You can only choose between the CANBUS box and the radar sensor.
Mikescotland dudu-lai ah OK. So second can2 port isn't active on C socket. OK. So my approach with translating and injecting into canbox protocol according to chosen canbox protocol is correct. Pity, could be "one solution for all". Thanks for the answer.
