  • Reversing Lines Menu - Backup Camera
Just a suggestion; Change the screen layout for the line configurations menu. It's challenging to adjust the backup camera reverse line width, height, left/right, etc when the configuration menu is blocking the center of the screen. It would be more user friendly if the adjustment menu were pushed to the side or near the top of screen vs taking up the whole center of the screen we are trying to adjust. Not sure if possible but would be nice. 🙂
It's not used very often, and after adjusting the ruler line you may not even bother clicking on it to see him, and when the ruler line is zoomed in, no matter how the window is placed, it blocks the
24 days later
@dudu-lai @DUDU-HUANG I guess you are right and these configuration parameters are typically used ince to set the parking lines up so it's ok to have them centered. What is not good, however, is that available adjustments are not enough to set up the praking lines if the camera installed off center. Currently parking lines are formed by the symmetric trapezoid which works ok if the camera is centered, but very often it is installed close to either right or left side of the car and in such a can align the right or left parking line with the curb but not the both.
What I would highly recommend is to implement a free-form transformation of the parking lines the same way is it is done in the UDT camera app.
Parking lines are very essensial for the every day drive experience and I think it worth investing some efforts into making them usable.
    Alex_S The camera we advocate to install in the middle of the rear of the car, or installed in the factory reserved camera fixed position, so that the viewing angle is positive, when the camera is off to the side to adjust the ruler line, the effect is always not as good as it should be!
    Sure, center camera position is preferred. But on my Suzuki Vitara the factory position is off center, because trunk door handle is in the center.
    Yet this can be easily compensated by the proper parking lines adjustment and this is not something too difficult to implement anyway.
    12 days later
    I would also like to request this feature to adjust the lines separately.
    I have the 360 camera installed and so far have been unable to set up the reversing lines. The front and sides are perfect however I have a Ford transit Custom with rear barn doors. The OEM location for the rear camera is in the rear registration plate light....approximately 100mm to the left of centre.
    I enable Reverse camera lines in the settings, however when I go to ADAS DVR and switch to the reverse camera it doesn’t show any lines.
    What can I do?
      dudulover The camera itself doesn't come with lines, they are only needed in the reversing screen to determine the distance
      DVR does not support displaying lines, so why do you want to see them in this application? What is the purpose?
      15 days later
      • Edited
      Is there any way to adjust the curve ratio based on the steering? I just find when turning the steering all the way, it almost shows 90 degree which is not nearly close to reality, so hope can have a way to adjust. Thank you!
      是否可以调整到车影像轨迹的转弯幅度?方向打到底的时候每次轨迹都无法完全的吻合应该有的轨迹,已经几乎90度了,希望可以增加这个调整选项,谢谢🙏
      3 months later
      I will like this feature please. Has it been implemented? Also on my reverse camara, why is that I can only change the dimensions of the inner grid lines?
      2 months later
      Plus one vote for feature to adjust curve ratio based on steering.
