  • 2k adas dvr camera imx 335
how to connect front camera and installation on dudu7
Hello, plug in the USB port of the DUDU7 and install the application in File Management - Logger Disk Drive
hi, I've tried that and I still can't get it to work and I'm also in doubt about where I should connect camera on the headunit
    Kiing You must connect it to any USB port that comes from the unit.
    I've tried but I still can't get the camera to work and the app says it's in Chinese so I'll do it from here
    Please look at @dudu-lai 's post.
    First you connect the camera to a USB port. Then you install the apk from the USB disk inside the camera. The camera has its own mini USB storage inside with the apk.
    Once the apk is installed, the camera should work
    do you mean on the headunit
      and how can I change the language on the app
        Kiing
        Yes, connect the camera via USB.
        Use the standard file manager of the unit and browse to the USB-disk inside the camera (USB1, USB2, whatever)
        Install the apk.
        I do not use this specific apk. i have no idea on how to set the language, but I had 3 other ones up till now. Most of the times when you touch the screen inside the app, you get a Settings "gear" where you alter things like language and so on.
        Kiing язык приложения будет такой, какой установлен в системе.
